I have bought myself a Woobm to manage routers with usb port.
However I have discovered that the Woobm won’t work with my hEX routers. (That is the only router type available to me with an usb port)
Firmware Woobm: 1.1
Firmware hEX: 6.44
If I plug it into my laptop and connect to the Woobm WiFi, everything is fine.
Ping response time: ~1-2ms (No load on the Woobm CPU)
Web management: Working flawless, load time: ~1-2s
If I plug it into a hEX and connect to the Woobm WiFi, the performance is absolutely horrible.
Ping response time: all over the place, never below 60ms; mixed with no ping response for a very long time period
Web management: Not working, sometimes fragments of it are loaded
Telnet: Partial working, but with unusable time offset
Does anybody have any clue, as to why this is happening?
Thank you!
–bpahlke
