work in console not in script
I’m a bit confused …
When I launch this command on console It Works and retun all the entries expected :
[/interface/wireguard/peers];
:foreach Id in=[find disabled=no] do={
:put [get $Id comment];
:put [get $Id last-handshake];
} But when this lines are put in a script file, I Have an error when running the script.
expected end of command (line 7 column 30) corresponding to the = sign in the line :foreach Id in=[find disabled=no] do={
Best regards.
Felix
If you don’t write correctly, it’s obvious that it doesn’t work, or that it works randomly.
Where did you read this and what does this represent?
@felix34, remove the brackets from the first line ie:
or:
:foreach Id in [/interface/wireguard/peers find disabled=no] do={
