I set band 5GHz-turbo.
Will i see (interface wireless monitor) rx and tx 108 Mbit?
Or rx tx - 54 Mbit, but radiochannel will work faster then in band 5GHz?
Yes, if you have it set to turbo, it is going two times faster.
I know it.
But what shall i see on the screen?
Shall i see 54 or 108 on the screen (command → interface wireless monitor ) - it’s my question…
You will see in the configuration that you have turbo set.
John
status: connected-to-ess
band: 5GHz-turbo
frequency: 5290
tx-rate: 54Mbps
rx-rate: 54Mbps
ssid: qvlink
bssid: 00:01:24:70:48:D4
signal-strength: -72
current-ack-timeout: 33
current-distance: 33
I don’t understand. Sorry.
My question about indicated digits - can they be 108 ? Or this utilite does not indicate digits higher then 54 ?
alex,
you have there 5ghz-turbo… rated speed is 54mbps. Thus, because you are using 2 channels {bonded}, you have 2x 54Mbps… you don’t see 108 there? Just a cosmetic issue…
Not think so…
With band 5GHz whithout turbo i have also 54 MBit rx tx.
This value only indicate possible speed on rx OR tx NOT SUMM - this not indicate real trasfer rate in time. IMHO.
I have real transfer rate 2.4 Mbyte/sec ~ 54 Mbit/sec (half duplex) on both band. Is developer here?
Can i get the answer for my quistion?
as said before, the displayed number will be 54, but the actual speed will be higher.
