Hi guys!
I have some scripts which is ok , and runing every 24 hours.
But I have problems :
I need this scripts to running from monday-friday , at weekend days (saturday and sunday) I dont need to use this scripts , and then I manualy (via winbox) disable scheduled scripts.
Is there any way to make some script which will be do this ?
How to make mikrotik to run these scheduled scripts only in working days?
To handle this we just use another two scripts and scheduler events. These extra scripts disable the scheduler on weekends and enable them weekdays. Here is an example of the scripts.
I then set up a Scheduler event to run the StartWeekend script on fridays at the desired time and another event to run the StartWeek script on Monday at the desired time.
