Very novice question here…initially I had my router set up to just use WPA2 with AES. But then I’ve discovered I’ve got some legacy equipment (A Linksys WVC200 and a Linksys Wifi VOIP phone) that only talk WPA+TKIP.
I enabled WPA and TKIP on the quick settings page and checked the Wireless security profile settings…it appears that WPA and WPA2 have the same password for the AP, which is fine.
However, none of the WPA-only devices can connect. I don’t see anything logged in the MikroTik router log either.
I have 2Ghz b/g/n enabled so they SHOULD be able to talk to it. Is there any chance the channel width might have something to do with it? I am using 20/40 Mhz HT above…
I would follow the suggestion from uldis and make a specific virtual AP under the main interface. You may also want to bridge that VAP to a different VLAN and treat it as less secure given the use of WPA & TKIP.
Hey folks: just a quick follow-up. Creating a VirtualAP with it’s own WPA-only security profile did the trick. The old equipment is now communicating again.
