I am trying without much success to get a routerOS CPE to authenticate to a Cisco 1310 AP using EAP-TLS. The Cisco AP has a radius server configured (FreeRADIUS), I have setup a CA on the FreeRADIUS box and it knows about the client / master keys and certs. I configured my MT CPE to use dynamic security profile with TKIP / AES and WPA / WPA2. The Cisco AP is configured to use Open authentication with EAP and mandatory WPA key management.
Attempting to associate with the AP using MT results in this:
21:01:53 system,info device changed by admin
21:01:54 wireless,info 00:15:F9:CC:55:00@wlan1 established connection on 2437, SSID fw-4000
21:02:04 wireless,info 00:15:F9:CC:55:00@wlan1: lost connection, decided to deauth: IEEE 802.1X
authentication failed (23)
21:02:06 wireless,info 00:15:F9:CC:55:00@wlan1: failed to connect, auth failed: association denied for
unknown reason (12)
However on the Cisco side of things, running with aaa/eap/dot1x debugging, I see the following:
Apr 5 01:01:54.754: dot11_auth_add_client_entry: Create new client 0015.6d53.942f for application 0x1
Apr 5 01:01:54.754: dot11_auth_initialize_client: 0015.6d53.942f is added to the client list for application 0x1
Apr 5 01:01:54.754: dot11_auth_add_client_entry: req->auth_type 0
Apr 5 01:01:54.754: dot11_auth_add_client_entry: auth_methods_inprocess: 2
Apr 5 01:01:54.755: dot11_auth_add_client_entry: eap list name: tls
Apr 5 01:01:54.755: dot11_run_auth_methods: Start auth method EAP or LEAP
Apr 5 01:01:54.755: dot11_auth_dot1x_start: in the dot11_auth_dot1x_start
Apr 5 01:01:54.755: dot11_auth_dot1x_send_id_req_to_client: Sending identity request to 0015.6d53.942f
Apr 5 01:01:54.755: EAPOL pak dump tx
Apr 5 01:01:54.755: EAPOL Version: 0x1 type: 0x0 length: 0x0029
Apr 5 01:01:54.755: EAP code: 0x1 id: 0x1 length: 0x0029 type: 0x1
018041D0: 01000029 01010029 01006E65 74776F72 ...)...)..networ
018041E0: 6B69643D 66772D34 3030302C 6E617369 kid=fw-4000,nasi
018041F0: 643D6170 2C706F72 7469643D 30 d=ap,portid=0
Apr 5 01:01:54.756: dot11_auth_send_msg: sending data to requestor status 1
Apr 5 01:01:54.756: dot11_auth_send_msg: Sending EAPOL to requestor
Apr 5 01:01:54.756: dot1x-registry:registry:dot1x_ether_macaddr called
Apr 5 01:01:54.756: dot11_auth_dot1x_send_id_req_to_client: Client 0015.6d53.942f timer started for 30 seconds
Apr 5 01:01:54.780: dot1x-ev:dot1x_mgr_pre_process_eapol_pak: Role determination not required on Dot11Radio0.4000.
Apr 5 01:01:54.780: dot1x-packet:dot1x_mgr_process_eapol_pak: queuing an EAPOL pkt on Authenticator Q
Apr 5 01:01:54.780: dot11_auth_parse_client_pak: Received EAPOL packet from 0015.6d53.942f
Apr 5 01:01:54.780: EAPOL pak dump rx
Apr 5 01:01:54.780: EAPOL Version: 0x1 type: 0x1 length: 0x0000
01803D10: 01010000 ....
Apr 5 01:01:54.780: dot11_auth_dot1x_run_rfsm: Executing Action(CLIENT_WAIT,EAP_START) for 0015.6d53.942f
Apr 5 01:01:54.781: dot11_auth_dot1x_send_id_req_to_client: Sending identity request to 0015.6d53.942f
Apr 5 01:01:54.781: EAPOL pak dump tx
Apr 5 01:01:54.781: EAPOL Version: 0x1 type: 0x0 length: 0x0029
Apr 5 01:01:54.781: EAP code: 0x1 id: 0x2 length: 0x0029 type: 0x1
018002E0: 01000029 01020029 01006E65 74776F72 ...)...)..networ
018002F0: 6B69643D 66772D34 3030302C 6E617369 kid=fw-4000,nasi
01800300: 643D6170 2C706F72 7469643D 30 d=ap,portid=0
Apr 5 01:01:54.781: dot11_auth_send_msg: sending data to requestor status 1
Apr 5 01:01:54.782: dot11_auth_send_msg: Sending EAPOL to requestor
Apr 5 01:01:54.782: dot1x-registry:registry:dot1x_ether_macaddr called
Apr 5 01:01:54.782: dot11_auth_dot1x_send_id_req_to_client: Client 0015.6d53.942f timer started for 30 seconds
Apr 5 01:02:06.330: dot11_auth_client_abort: Received abort request for client 0015.6d53.942f
Apr 5 01:02:06.330: dot11_auth_client_abort: Aborting client 0015.6d53.942f for application 0x1
Apr 5 01:02:06.330: dot11_auth_delete_client_entry: 0015.6d53.942f is deleted for application 0x1
This “received abort request” I can’t figure out where it is coming from. Looking at the radius server logs shows no attempt was even made to authenticate against radius.
Has anyone managed to get dynamic key management with a strong crypto and 802.1x / EAP-TLS working with MT / Cisco gear? Everything I’ve read says this should be really simple as the Cisco AP should just forward the EAP info off to the radius server and get back an OK or failure, but I can’t figure out what’s going wrong on this setup. Judging by the timestamps, it looks as if the MT is doing the actual disconnect, but why? How can 802.1x fail if the radius server never even got asked?
