Hello, I’m new of Mikrotik product.
I have an hAP ac and 2 Asus Router that I use as Access point. I configurated my Mikrotik WiFi in this manner (with Radius Authentication):
/interface wireless print detail
0 R name="wlan1" mtu=1500 l2mtu=1600 mac-address=xx:xx:xx:xx:xx arp=enabled
interface-type=Atheros AR9300 mode=ap-bridge ssid="Bla"
frequency=2462 band=2ghz-b/g/n channel-width=20mhz scan-list=default
wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1 wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=EAP-RADIUS
compression=no
1 name="wlan2" mtu=1500 l2mtu=1600 mac-address=xx:xx:xx:xx:xx arp=enabled
interface-type=Atheros AR9888 mode=ap-bridge ssid="Bla"
frequency=5200 band=5ghz-a/n/ac channel-width=20/40mhz-Ce
scan-list=default wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1
wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=EAP-RADIUS compression=no
My problem is that on Asus Routers I see in wifi properties of my phone (with Wifi Analyzer app) :
[WPA2-EAP-CCMP+TKIP-preauth][ESS]
on Mikrotik board I see:
[WPA2-EAP-CCMP+TKIP][ESS]
The difference is pre-auth tag that is missing on Mikrotik router. Can I add it?
