wpa2-pre-shared-key not receive value 64 hexadecimal digit
MikroTik RouterOS 6.37.3 for example, not properly receive value as a 64 digit “0”
wpa2-pre-shared-key=“0000000000000000000000000000000000000000000000000000000000000000”
Acces point with this settings is not accessible from station with win 7. When using a string of 63 ASCII digits “0”, then it is OK. But it is not a hexadecimal key.
Example settings
name=“orion” mode=dynamic-keys authentication-types=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa-pre-shared-key=“”
wpa2-pre-shared-key=“0000000000000000000000000000000000000000000000000000000000000000” supplicant-identity=“” eap-methods=“” tls-mode=no-certificates tls-certificate=none
mschapv2-username=“” mschapv2-password=“” static-algo-0=none static-key-0=“” static-algo-1=none static-key-1=“” static-algo-2=none static-key-2=“” static-algo-3=none
static-key-3=“” static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key=“” radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting=no
interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username radius-mac-caching=disabled group-key-update=5m management-protection=allowed
management-protection-key=“”
