WPA2 PSK + DaloRadius + Freeradius
Hi there! First of all, I know there are other posts about this problem but they didnt solve my issue, so Im posting here to see if we can make my config work :slight_smile:
Right now I have a FreeRadius daemon running on a CentOS distribution in a virtual machine on a XenServer. I have DaloRadius configured on the same VM also. I have a RouterOS working as a hotspot server in a interface connected to a RB532. This server is also a PPPoE concentrator using UserManager, wich I will try to migrate to FreeRadius also. Well, My problem is that:
My FreeRadius gets the call from the RB when a client try to connect, I use Mikrotik-Wireless-PSK = “PSK” as a reply attribute using the := op and I see in the logs that the RADIUS send to my RB the info, but for some reason My RB shows “last failure, received deauth”. I think maybe I misplaced some info on the DaloRadius database, but I want the opinion of you guys so I can get WPA2 PSK to authenticate using Radius for the key!
X86 |Wired| X86 |Wired| RB532 |Wireless|
RADIUS ----------->PPPoE and HotSpot Server ------------> WPA2 + RADIUS auth---------------->Clients
Anyway, I wanna know how exactly can I do to make WPA2 PSK on RouterOS to authenticate using a Freeradius with MySQL(wich is already configured). I hope I made myself clear about the problem, any info needed just ask!
I hope that you are not using PSK as preshared-key for WPA configuration, it should be at least 8 symbols long.
Configuration required on MikroTik router for the PSK authentication/authorization over RADIUS.
/radius add address=server_IP service=wireless secret
/interface wireless security-profile configuration for WPA2-PSK.
Hi there, Actually Im using for WPA and WPA2 but all my PSK are longer than 8 digits. The config you suggest is already done in my RouterOS, the problem isnt that… As I see, the RB refuses to authenticate when the reply comes from the RADIUS server. I run FreeRadius on debug mode and can see the requests and the Access-Accept reply, but on the RB logs it only shows “got from RADIUS” when its an Access-Reject. And when its Access-Accept, the MAC dont auth returning the message I told earlier. Its really strange why that is happenning! Still looking for a solution, any feedback would be nice, if I got any solutions I will post here as well.
Hi again, so.. any ideas? I dont think its a complicated thing to do because a lot of people already use this method, I just wanna know why my system isnt working right. When it goes to the RADIUS server it dont auth. Correct me if Im wrong. First, if I have a wlan interface without WPA2 active, i dont have to put MAC on the address-list if I want the system to search on the RADIUS database right? And in a WPA2 scheme I just have to register the MAC and the Mikrotik-Wireless-Psk info on the RADIUS database to auth right? The Mikrotik-Wireless-Psk is a check or a reply attribute? Do I use :=, = or == to set the attribute on the RADIUS server? Any advice will be welcomed.. thx guys!
Enable ‘radius,debug’ logs at /system logging and post here the output, when wireless client is trying to connect to the router.
As requested, Im sending the file with the logs. Just for the record, its telling that it got timeout but I checked the Server and its with radiusd running and also receiving the packets from my RouterOS! Any help would be great :slight_smile:
log.1.txt (78.4 KB)
What configuration do you have at /radius print at the router?
[xxxx@BrNet - POP Principal] /radius> print
Flags: X - disabled
SERVICE CALLED-ID DOMAIN ADDRESS SECRET
0 wireless 192.168.1.2 idp4206
Thats it, the IP is from an address I have in a interface connected directly with my radius server. This config above is from a RB532 witch is connected to a X86 PC with RouterOS, the X86 PC has the direct connection with the radius server.
Ok, /radius export is needed.
/radius
add accounting-backup=no accounting-port=1813 address=192.168.1.2
authentication-port=1812 called-id=“” comment=“” disabled=no domain=“”
realm=“” secret=xxxxxx service=wireless timeout=300ms
/radius incoming
set accept=yes port=1700
Sorry for the delay to answer!
Hi there, Im still trying here but without success… any ideas so far?
Hi, so any ideas? Im still stuck!
/radius configuration is correct.
Just one thought, do you have any masquerade rules?
You should look what is wrong on the RADIUS.
