Hi again,
I have now enabled debug-messages for Wireless on the RouterOS, and I tried again several times. But before I post the results, let me explain how I do this:
- I have a WLAN with SSID broadcast
- The WLAN is Bridge AP
- The phone has a WLAN-scanner, and I can choose to connect to a WLAN and check if I get access to the Internet
- It’s this WLAN-scanner and the Internet-check I use to verify connectivity
First I disabled security, running an open network:
Jul 30 14:28:05 wireless,debug wlan1: 00:1C:D6:30:41:BA attempts to associate
Jul 30 14:28:05 wireless,debug wlan1: 00:1C:D6:30:41:BA not in local ACL, by default accept
Jul 30 14:28:05 wireless,info 00: 1C:D6:30:41:BA@wlan1: connected
Then I turned on both WPA + WPA2, and typed in the WPA PSK:
Jul 30 14:32:05 wireless,debug wlan1: 00:1C:D6:30:41:BA attempts to associate
Jul 30 14:32:05 wireless,debug wlan1: 00:1C:D6:30:41:BA not in local ACL, by default accept
Jul 30 14:32:05 wireless,info 00: 1C:D6:30:41:BA@wlan1: connected
WPA + WPA2, and typed in the WPA2 PSK:
Jul 30 14:33:03 wireless,debug wlan1: 00:1C:D6:30:41:BA attempts to associate
Jul 30 14:33:03 wireless,debug wlan1: 00:1C:D6:30:41:BA not in local ACL, by default accept
Jul 30 14:33:03 wireless,info 00: 1C:D6:30:41:BA@wlan1: connected
Jul 30 14:33:08 wireless,info 00: 1C:D6:30:41:BA@wlan1: disconnected, unicast key exchange timeout
Error-msg on the Phone: Error: Bad WPA key
WPA2 only, using the WAP2 PSK:
(nothing in the logs)
Error-msg on the Phone: Error: WLAN network not found!
WPA only, using the WPA PSK:
Jul 30 14:40:22 wireless,debug wlan1: 00:1C:D6:30:41:BA attempts to associate
Jul 30 14:40:22 wireless,debug wlan1: 00:1C:D6:30:41:BA not in local ACL, by default accept
Jul 30 14:40:22 wireless,info 00: 1C:D6:30:41:BA@wlan1: connected
As long as I use WPA or Open Network, it works, but when I try WPA2 it does not. But when using my last AP (OpenWRT), it was WPA2 only and the phone worked. I also use my phone in other WPA2-only networks and that works also.
I also tried to change the key, no luck.
Can I add more debugging? Or do you have other hints and tips I can try?
Regards,
Vidar Hoel
