Hey all,
Short summary: I want to setup a Mikrotik AP with WPA2 encryption using EAP-TTLS+PAP against a Radiator RADIUS server.
I know the subject “EAP-TTLS” has been subject of a few posts in the recent years. But even though I used the search quite a bit, I cannot get a clear and plain “YES” or “NO” to my question.
- http://forum.mikrotik.com/t/mikrotik-eap-ttls/49676/1
- http://forum.mikrotik.com/t/help-wds-wpa2-eap-freeradius-failure/40854/1
- http://forum.mikrotik.com/t/eap-ttls-pap-authontication/35246/1
There has even been a feature request for EAP-TTLS support http://forum.mikrotik.com/t/feature-request-eap-ttls-eap-peap/64120/1 which confused me even more.
So please excuse me opening another post to the subject …
I am running a RB2011 and have another RB 751G to play with and would like to achieve the following:
a) Have a an AP with WPA2 security and EAP
b) As EAP “layer” I’d like EAP-TTLS to have a secure and authenticated (SSL certificate) TLS tunnel towards my authentication server
c) Inside the EAP-TTLS tunnel I’d like to do PAP (yeah it’s plain text, but the TLS from EAP-TTLS protects the data here. The PAP should then check username/password against a RADIUS.
Pretty much like it’s described here http://www.juniper.net/techpubs/software/aaa_802/sbrc/sbrc70/sw-sbrc-admin/html/EAP-024.html.
This kind of setup (EAP-TTLS) is widely used by eduroam (https://www.eduroam.org/) that allows university students to use wifi at pretty much every other university.
There is some documentation of how to set this up on the radius side( https://confluence.terena.org/display/H2eduroam/How+to+deploy+eduroam+on-site+or+on+campus) , but unfortunately there is nothing on configuring a Mikrotik AP accordingly. There is also another post http://forum.mikrotik.com/t/eduroam-with-mikrotik-aps/76111/1 which asks particularly about setting up an eduroam AP.
My questions are:
a) Can this even be done with Mikrotik?
b) How do I set up the wireless security-profile for such an AP? Is passthrough the right option here and will everything else then be done by the RADIUS?
c) How and where do I configure the TTLS tunnel endpoint? (“Server” in the Juniper example). Is that automagically the RADIUS server?
d) If then the tunnel endpoint is set, how do I tell the client to do PAP inside this tunnel? Is that done by the RADIUS or is there anything I need to set on the RB?
Thanks for you help !
