Wrap doesn't reboot!
Only want to know if others experience the same, all my wraps boards (like 12) doesn’t remotely reboot, I have to go there and turn off and turn on the router, they have versions 2.8.2*+ and 2.9.27, I dont remember from what version they stop to reboot normally, with the routerboards I am ok at rebooting remotely. :astonished:
I am not so friendly with wrap but as I know you should have the routerboard package installed so the wrap can reboot .
Regards Durim
I find it somwhat random - ordinarily it seems to be those inaccessible that the failure to reboot occurs on, despite having the routerboard pkg
installed. Perhaps some characteristic of the individual flash?
