What kindof throughput can i expect for two wraps(233 or 266mhz/ 64mb or 128mb of ram) with 1 sr5 per wrap in WDS? i know on rb532 i can get ~23mb, but due to unavailability of rbxxx i must use wraps.
Around 20’s Mbps stable tops.
Thx
//Budi
cpu limited?
Yes.
Thx
//budi
anyone know what kindof bandwidth the rb112 will be able to do? more or less than the wrap?
In ideal conditions (in the same room) I get 25mbit TCP on mikrotik bandwidth test being run on the wraps.
These are Wrap 1e’s with CM9 cards
When i do an ftp transfer when the cards are in turbo mode I get 5MB/sec transfers ![]()
setssquare:
so you think you are getting around 40-50mbit on wraps? so wraps can do this much when not generating the traffic as well as beaming it?
Just messing around i’ve goteen 22-25 mbit between two wrap 2c 's @ 2.4
tks
Wrong!
setssquare:
tks
From my experience… yes
But remember I had no firewall or que rules and was running turbo mode 2.4ghz.
I was surprised when I saw these high speeds to after reading in many posts the that WRAP is only got for 25mbit TCP.
jo2jo:
setssquare:
tks
yes only 20mbps tops, cpu shows 100%
that would be when you use bandwidth-tester on that very same wrap.
stop doing that, it doesn’t measure -throught-put-
LOL, wrap to wrap would be called “TO PUT” because your not going through it, your going to it.
sten:
stop doing that, it doesn’t measure -throught-put-LOL, wrap to wrap would be called “TO PUT” because your not going through it, your going to it.
LoL, “TO PUT”, i will have to remember that one ![]()
