Write command output to a file
Hello
Can i write to a file the output of a command ?
I want to save the output of a “interface wireless scan wlan1-gateway”
Is this possible while I am connected to the RB via wireless interface ?
Thanks.
Scanning to file is possible with wireless-rep or v6.37rc
Thank you..
Where can I find information about wireless-rep ?
RouterOS 6.37 is needed, “rep” no longer exists.
Here is how to use it:
[admin@sviests] > interface wireless
[admin@sviests] /interface wireless> scan wlan1 background=yes save-file=results.txt duration=4s
Flags: A - active, P - privacy, R - routeros-network, N - nstreme, T - tdma,
W - wds, B - bridge
       ADDRESS           SSID        CHANNEL   SIG   NF SNR RADIO-... ROUTER...
[admin@sviests] /interface wireless> /file print
 # NAME        TYPE        SIZE CREATION-TIME
 0 flash        disk        jan/01/1970 03:00:00
 1 results.txt
