after over a year of only using 2,4GHz on my hAP AX3, which I am using as access point, I’ve somewhere here found that changing the country code makes the hAP AX3 usable.
So I gave it a shot and changed my config via the mobile app. My initial config was very minimal, just bridging the LAN ports and offering two SSIDs for 2,4GHz and 5,0GHz WiFi.
After having added
configuration.country="United States"
to my config for the 5GHz network it is like day and night. The 5GHz network was so bad, I would get 400mbits right next to the device, but only a few meters and I would get like maybe 10mbits, sometimes way less. I haven’t used the 5GHz network because of that for ages, as I don’t really need the fast speeds wireless.
After the change I get like 800+ right next to the device and around 400 where I could get maybe 10 before.
Is that huge change to be expected by changing the country settings? Am I completely fucking over my neighbors by doing that?
The resulting config looks like this:
# 2025-06-12 00:45:11 by RouterOS 7.16.2
# software id = JV3Q-KDY8
# model = C53UiG+5HPaxD2HPaxD
# serial number = ***
add name=local port-cost-mode=short
/interface wifi security
add authentication-types=wpa2-psk connect-priority=0/1 disabled=no name=\
fbclone wps=disable
/interface wifi configuration
add country=Germany disabled=no name=fbclone24 security=fbclone ssid=\
myssid24
add channel.skip-dfs-channels=all country=Germany disabled=no name=fbclone50 \
security=fbclone ssid=myssid50
/interface wifi
set [ find default-name=wifi1 ] configuration=fbclone50 \
configuration.country="United States" .mode=ap disabled=no mtu=1500
set [ find default-name=wifi2 ] configuration=fbclone24 configuration.mode=ap \
disabled=no
/ip smb users
add bridge=local interface=ether2 internal-path-cost=10 path-cost=10
add bridge=local interface=ether3 internal-path-cost=10 path-cost=10
add bridge=local interface=ether4 internal-path-cost=10 path-cost=10
add bridge=local interface=ether5 internal-path-cost=10 path-cost=10
add bridge=local interface=ether1 internal-path-cost=10 path-cost=10
add bridge=local interface=wifi1 internal-path-cost=10 path-cost=10
add bridge=local interface=wifi2 internal-path-cost=10 path-cost=10
set udp-timeout=10s
/ipv6 settings
set max-neighbor-entries=15360
add address=192.168.178.210/24 interface=local network=192.168.178.0
set servers=192.168.178.1
/ip ipsec profile
add dst-address=0.0.0.0/0 gateway=192.168.178.1
/ip smb shares
set [ find default=yes ] directory=/pub
/system clock
/system logging
add topics=wireless,debug
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=192.168.178.1
