Wrong dynamic route for Wireguard interface?
sorry for newbie question. I just upgraded to hAP ac^2 (RouterBOARD D52G-5HacD2HnD-TC) to routeros 7.4 to gain option to setup the wireguard VPN. At the end I managed it to work, but:
There is something I dont understand (BTW I am using Winbox).
When the Wireguard interface is created and the IP address is set, the new Dynamic route is added. I am suspitious there is a bug.
adding:
IP address: 192.168.100.1
network: 192.168.100.0
interface: wireguard1
automatically creates this entry in the routing table:
(DAC) 192.168.100.0**/32** wireguard1 distance 0
The mask /32 looks odd to me, would expect /24 ? (and this is what I found in the documentation in section IP and routing configuration here: https://help.mikrotik.com/docs/display/ROS/WireGuard )
Actually adding manually 192.168.100.0/24 route to the table fixes the problem. Unless the Dynamic entry can not be deleted.
Could anyone confirm the bug or explain my misunderstanding, pls?
Thanks.
When adding IP-addresses you need to be specifying /24 !! or it will assume a /32
So …
adding:
IP address: 192.168.100.1**/24**
As JV points out, the bug or problem is you LOL.
A proper address will result in the correct route.
The result you have is exactly what you should expect for the address you gave the router.
Thank you Jvanhambelgium, you are right. Winbox might better treat the IP address input there, that was not obvious to me.
Hmm, Anav, I was curious if some comment from you arrives…
Hahaha, yes
https://forum.mikrotik.com/viewtopic.php?t=182340
