wrong filter add cant login mikrotik
hi
i added wrong ip firewall filter add cant login mikrotik
my mikrotik port is : 9000
so there is any way disable all ip firewall filter?
anyone help me please?
thank you advance
Have you enabled mac Server? Then you can Connect via Mac. Or SSH.
MAC same
ssh login via putty?
ssh same putty cant login
Does the machine have a serial port or at least an USB port?
