Hello, I need some help with regards to the DHCP Server + BRIDGE setup, because I don't know why I get wrong IP address on a new bridge I create
I've started from the defconf. My WAN is working and there is a default bridge called bridge.
Steps I took
- created a new bridge called
LAN_BRIDGE - added 3 interfaces (eth4,5 & wlan1) to a bridge called:
LAN_BRIDGE - Gave
LAN_BRIDGEan ADDRESS of: 192.168.50.1/24 NETWORK: 192.168.50.0 - Created DHCP server with interface:
LAN_BRIDGE - Created DHCP server network with ADDRESS: 192.168.50.0/24, GW: 192.168.50.1, NET MASK: 0
The Issue
When I connect to one of the ports assigned to the LAN_BRIDGE I get assigned a wrong IP address IPs I get belong to the defconf network 192.168.88.0/24. What did I do wrong in this configuration and why I get wrong leased IP addresses?
