Wrong nat port
Yes, thank you i knew that. I was just confused why i couldn t test my pppoe connection in an isolated case (fixed user station) without compromising the live network, on the same router. Looks like i can t, without the use of the mentioned mechanincs. I ll deffinitely implement policy routing because it s the most suitable option for my specific need.
The simplest is ecmp, no distance difference, but most want or need more control and its not so good if there is an imbalance in the throughputs of both providers.
ecmp rarely is a solution for the case at hand, because you cannot control where a specific packet will go out. what you need is a separate routing table with a default for ISP2 and routing rule that sends the traffic with source address corresponding to ISP2 to that second routing table (in his case probably easiest to use the ISP with the fixed subnet for that), and in addition you need to set a route mark on connections incoming to guarantee that the reply will go back the same way.
Then, you can use a PCC rule to mark a “balanced” part of forwarded traffic from the LAN with a routing mark that will send it via one of the two.
Looks like pcc worked, and indeed route marking with the default route to the pppoe interface, with a second routing table does the work done. Thanks for the effort to reply.
Steve.
