Hi!
If you happen to download the firmware twice so you get for example a routeros-arm-6.46.1 (1).npk, upload that to the router and reboot. Then system halts before loading kernel. Netinstall is required to bring the device back to life. I think the device should either handle the extra characters or simply don’t try to load the file.
Kind regards
David
