Hi!
I have problem with services for each node…
If I go to device settings and then to services I see lets say 3 services: ping, mikrotik and router
If I click on general I see there that there are 6 services up. This is not the problem until the services are down. If this device fails, I see under services that ping, mikrotik and router are down, but under general there it says that 3 services are up and 3 services are down…so it is orange instead of red…
I think this problem was introduced in 2.0beta 11 or beta10
thank you if you can fix this…
