hi all
I use this code
/ip arp remove [/ip arp find address=172.16.1.254 and mac-address=AC:7B:A1:B3:D4:77 and dynamic=no ]
in my custom script
but its work in wrong way and removes both (172.16.1.254 & 172.16.1.253) from ARP table
i don’t know why?
Splash
2
I tested this on my router and dont seem to have the same issues when running this command.
/ip arp remove [/ip arp find address="192.168.19.76" and mac-address ="00:00:00:00:00:12" and dynamic=no]
If you just run the command on its own and not in your script, does it do the same thing?
yep
this find return 2 number instead of 1
Splash
4
Hmm,
Can you try put the arguments in " quotes and see if that helps?
What ROS are you running?
this is not my problem
here is my On logout script for my hotspot
:local "hotspot_user" $user;
:local "hotspot_address" $address;
/ip firewall nat remove [/ip firewall nat find src-address=$address];
/ip arp remove [/ip arp find address=$address and mac-address=$"mac-address" and dynamic=no ];
:log info "User $user with ip-address $address and MAC $"mac-address" Interface $interface logged out!"
on login
/ip firewall nat add action=masquerade chain=srcnat out-interface-list=Data hotspot=auth comment="NAT" src-address=$address;
:log info "User $user with ip-address $address and MAC $"mac-address" Interface $interface logged in!"
ip arp add interface=$interface address=$address mac-address=$"mac-address";
Splash
6
this wouldnt work as you have put the quotes after the $
$“mac-address”;
should be
“$mac-address”;
nop if u read the Doc for scripting
variables which has dash between words should be used like $“mac-address”
u can test it
use this
