My cable is a straight ethernet cable, plus an rj45 F - DB9 F adapter
RJ45 DB9F
8 7
7 4
6 3
5 5
4 5
3 2
2 6
1 8
As you can see, both 4 and 5 from rj45 go to pin 5 (GND) on the db9 , but in your image there is only one GND wire, and other wires are different from the table below.
My cable seems working and is built like the pinout table on the wiki says , but please confirm if the image is wrong or if there are more ways to build serial cables…
I’m using a straight ethernet cable (not rollover) and a rj45-db9 adapter , wired the way I’ve posted before.
Again, in the wiki image there are no serial pins connected to TWO wires, while in the table below both 4 and 5 from rj45 go to 5 (ground) from db9.
There are interrupted wires, while in the table every rj45 pin is connected.
tx-rx are 4-5 in the picture, while in the table below 4 and 5 are ground.
pinout read from table is different from what the picture represent.
My cable is built like the table says, and it works.
Image refers to something different, so I’m wondering if it’s wrong…
