VLANS
I have following setup - WRT54GL running in meeting room. Configured to have 2 Wireless SSID’s and 2 matching vlans (VLAN5, VLAN6).
On the other end , there is Mikrotik 433GL (ethernet 2). It has also 2 Wireless SSID’s. One for public, one for private lan just like wrt54gl.
Mikrotik has one ether for our private lan and one ether for WAN.
[admin@MikroTik1] > interface vlan print
Flags: X - disabled, R - running, S - slave
# NAME MTU ARP VLAN-ID INTERFACE
0 X VLAN5_PUBLIC 1500 enabled 5 eth2_phyPubLan
1 X VLAN6_PRIVATE 1500 enabled 6 eth2_phyPubLan
[admin@MikroTik1] > interface bridge print
0 R name="PrivateLAN" mtu=1500 l2mtu=1524 arp=enabled
mac-address=D4:CA:6D:7E:75:59 protocol-mode=none priority=0x8000
auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m
1 R name="PublicLan" mtu=1500 l2mtu=1524 arp=enabled
mac-address=D4:CA:6D:7E:75:5A protocol-mode=none priority=0x8000
[admin@MikroTik1] > interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 WlanCard1_r52Hn PrivateLAN 0x80 10 none
1 eth1_phyPrivLan PrivateLAN 0x80 10 none
2 eth2_phyPubLan PublicLan 0x80 10 none
3 I WlanCard1_Virtual1 PublicLan 0x80 10 none
4 X VLAN6_PRIVATE PrivateLAN 0x80 10 none
5 X VLAN5_PUBLIC PublicLan 0x80 10 none
[admin@MikroTik1] > interface ethernet print
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R eth1_phyPrivLan 1500 D4:CA:6D:7E:75:59 enabled none switch1
1 R eth2_phyPubLan 1500 D4:CA:6D:7E:75:5A enabled none switch1
2 R eth3_phyWAN 1500 D4:CA:6D:7E:75:5B enabled none switch1
[admin@MikroTik1] > interface ethernet switch port print
Flags: I - invalid
# NAME SWITCH VLAN-MODE VLAN-HEADER
0 eth1_phyPrivLan switch1 disabled leave-as-is
1 eth2_phyPubLan switch1 disabled add-if-missing
2 eth3_phyWAN switch1 disabled leave-as-is
3 switch1_cpu switch1 disabled leave-as-is
I have tryed the switch port vlan mode to set “check”, “fallback” and “secure”.
What am I missing?
I can see traffic coming in from wrt54gl on interface but torch shows no vlan id’s (coming or going).
Used this one as a guide: http://wiki.mikrotik.com/wiki/Vlans_on_Mikrotik_environment
Mikrotik 5.25 sw,
Model 433GL
Current Firmware 3.02
If topology is described too unclearly then let me know and I will try one more time.
Disregard “disabled” states sincei have temporarily disabled vlans on interface so that atleast public wifi would work in there.
