in rb133c
wt is the meeaning of
RouterBOARD 133C’ with MIPS CPU, 16MB RAM, one LAN, one MiniPCI, 64MB NAND Storage with RouterOS Level 3 (CPE support)
i want to use it at ap ?can i ?
No. CPE means it works only as a client device. In general, level 3 licence doesn’t support AP mode.
As an AP you can use RouterBoard 133.
regards
r u meean recive only not send ??
no. It means it can connect to an AP, but you can’t use it as an AP for serving customers.
[Home] – [RB133c] —> [AP RB133] <---- [RB133c] – [Home]
wt is the config to set rb133 as ap ?
i have mikrotik OS on pc
thnx Mr. normis
