WTF... On first day i have a hacker knocking on my door...
A normal thing…
So you have Firewalled your Router?
Also change the ports for your services from usual / default. Th services will still work fine, just need to remember to append the port # at the end of your login.
You won’t see the “knocking” so much if they can’t find the door…
Also this will help http://wiki.mikrotik.com/wiki/Bruteforce_login_prevention
