www-ssl service with SHA-2 certificate
I am not sure, but I am unable to import a SHA-2 certificate to RB951G-2HnD, it seems to me that MT doesn’t support any other ssl certificate except SHA-1, isn’t it ?
Will be supported SHA-2 in the future and when ?
Is there some workaround ?
Tlamik
The same problem happened with me, when I bought ssl certificate from ssl2buy.com, which was also equipped with SHA-2 algorithm. However I was not able to import a SHA-2 certificate to RB951G-2HnD. Is there any time limit for this issue to be solved? Should I reissue certificate with SHA-1 algorithm?
If i go with SHA-1 algorithm, it seems and proved a weak algorithm in current time. Please suggest me what can i do to avoid such issue?
