X-BOX problem
Hy,
I have a problem with clients, that use X-BOX live.
I use load ballancing (2.9.1)
If I don’t use the second line, (no load balling)
the X-BOX connection work fine.
Play the client over both lines (load ballacing), He lost the connection after few minutes.
Can anybody help me??
this could happen for any online game. imagine it makes each connection through different gateway, and the server on the other end can’t understand how this player could be coming from 2 addresses so this disconnect happens. you should use policy routing and make the xbox users connect through one specific gateway, and make the others do load balancing. or something like that
Hy,
I have made a static route.
IP ROUTE – Dest=192.168.2.33/32 Gateway=62.xxx.xxx.xxx
But I have the same problem.
