x86 and 1Tb hdd dont work
i first thought that it was the hdd as i found this online
http://www.seagate.com/www/en-us/support/downloads/seatools
now what happens is when i plug it into the pc it show 33mb and not 1 tb
even if i put in anothere linux pc i have 33 mb
so i found that there is a problem with capacity but can be fixed with the tools
but no
the hdd seems locked
cant format or del partion
so i thought bad bath hdd so i got a new one btu ges what same thing
happend
so i thought cant be
so i got a new 1t hdd diffrnt make
and with my luck all works well exept when i plug it into a x86 mikrotik box then my hdd is fucked what can i do
i emailed support but mothing much yet has come from it has anyone got some tools i can use to fix the hdd capactiy with or maybe reload th fw again on a 1 tb westindigital hdd
thanks for the support
Seems ridiculous to put a 1tb disk in a router. Just my 2 cents.
well it works well x86 with 2 gig ram and 1TB FTP usage
Maybe there is pin, that limits capacity to 32 Gigs, or some settings in bios.
thats not it but ill find this problem as i have done some testing and so for looks like bois on motherboard thats not supported by mikrotik
well,what bios is showing is what it is showing, that is reported back AFAIK. Mikrotik is neutral to all motherboard vendors.
edit:
also, for FTP server i would suggest to install FTP server, as that will provide with more FTP features than FTP server in RouterOS. That is - if you really need FTP server, and not some small and temporal data storage, and 1TB is hard to call temporary or small. At least in year 2009.
