Performance of the RouterBOARD 433 is available on www.routerboard.com
Consider all the steps of the installation, when router will be up high in the mast.
There are not any problems to run OSPF on RouterBOARD 433 with 3 wireless interfaces on high load.
i’m also using x86, however, performance-wise i would go for 433ah. If you use a lot of cards on x86 you will have interrupt and bus problems (you can’t use the whole bandwidth potential of all cards at once), however, if you divide that task to 3 433-s it will work ok.
ie like below:
-Connect each RB433 to a different ethernet port of X86 via cat5
-Create 3x vlans between each RB433AH and the X86. ( 9 in total on the X86)
-Bridge each wlan interface to a vlan on each of the RB433AH’s.
-Do all the routing/ospf/mpls on the X86
