x86 Mikrotik on ESXi v5.5 Loses all network Connectivity
I have a x86 Mikrotik Router 6.22 originally then upgraded to 6.23RC and now 6.23 running on x86 virtual Machine. I have a 4 e1000 nics (MTU 1500) and 1 e1000e nic (MTU 9000) I have configured MPLS and VPLS so I can pass VLANs to my offsite locations running RB750GLs 6 in total. The problem I am having is the x86 host does not crash, log, error anything on screen and I can still login to it but all ethernet adapters go down. This does not happen on any of my other virtual machines and I have tried multiple ideas before posting here. I will quickly summarize what I have tried.
  1. Re-configure Network Adapters on Mikrotik and ESXi
  2. Disconnect Ethernet Adapters on ESXi
  3. Remove all but the single host that has been working for the offsite location
  4. Disable all other MPLS connections except one to see if a RB750GL is causing the issue.
  5. Changed MAC Addresses to confirm that their were no conflicts.
  6. Confirmed MTU is high enough for all locations so its not just silently failing.
  7. While Host is up and network is working traffic passes fine through all VPLS connections
The only solution after I get my notification from nagios that the host is no longer replying to pings is to just login to the console via ESXi and issue the /system reboot command and when the host reboots the network adapters just start working again.
When MPLS is not set up and running the host stays stable and I have yet to see it crash. The problem is I can’t make it crash on demand which means I get to wait. I have turned on debugging and nothing is visible when that happens.
Does anyone else have any ideas?
I’m having exactly the same issue. How did you solve it?
Only way to put the x86 back on track is by doing a reboot.
