We have a HP DL580 G5 Quad Core Quad Processor on ESXI 5.1 under heavy traffic with the multi cpu enabled it crashes about every 24 hours if you disable the multi cpu it runs stable, it also appears the when you have a lot of mangle rules with the multi cpu enabled it crashes 2 to three time a day. When it crashes you have no remote console in the VSphere client or no autosupout.rif to send support. Has anyone see this issue? Just happened again the only information in the vmeare console it the cpu usage goes to 100 percent on that vm machine
