x86 running 6.35.4 won't upgrade
Trying to upgrade to 6.36 and regardless if I use Winbox/System - Packages or manually copy the files over, the router will not upgrade. It reboots, deletes the files, and is still running 6.35.4. Any help would be appreciated! Thanks.
Anyone?
When you go to /system packages what does it show? I’ve noticed if you go from a “main package” type install to an “extra packages” type install you sometimes need to go to system packages and tell it to uninstall the combined older version after upgrading. It should reboot and start with the newer version.
Ussualy the log helps.
“router was rebooted without proper shutdown” is what I’m seeing in the logs.
In fact, just trying to disable or remove the dude package and reboot gives me the same error and nothing happens to the package.
Just rebooting the router normally is now giving me the error as well.
similarly, x86 not updated to 6.35.2 6.36.
