x86 v6.0 Mikrotik problem
Today we decided to upgrade some custom mikrotik using supermicro mobo / E3-1230v2 xeon cpu / with (4) dual intel pro 1000 nics
this server have always been < 10 % cpu usage this MT is 24/7 with 100k connections, 10k to 16k pps, 45 Mbps.
As soon as we upgraded we noticed massive packet loss!! from lan/wan and all this with 3% cpu usage. I could not test other brand of Ethernet because of the time, but I mean Intel dual PRO/1000 is like the most common used card in the world.
We downgraded to v5.25 and no problem, no packet loss.
Anyone have experienced this on x86 v6.0 MT?
thanks in advance.
I´m experiencing this same problem, but with INTEL 82571EB NIC. No problem with 5.25 at all.
regards,
Paulo Coimbra
Up, Intel boards. Please fix.
Update: I have found no solution with Intel boards for 6.0. Same problem on non-Intel boards on a different system, same packet loss. X86 simply looses packets on interfaces on more than 10Kpps links.
The issue also affects intra-router communications such as vrrp sessions which do not work properly anymore due to packet loss and master/backup configurations just work randomly. BGP sessions disconnect frequently due to the same issue.
@normis: can you confirm the bug?
Regards.
Not sure if this is related but…
Today my RB493G died, but luckily i have VRRP (fallback router is sitting inside ESXi VM. Also supermicro mobo (X9SCL±F) with Xeon E3-1230v2) and puchased license just couple of days ago…
Well this is all offtopic. VRRP took master role to that VM box. I noticed strange lags and ran a quick test to verify everything is OK.
Not everything, i have around 3-5% packet loss to default gw (located on VRRP interface). No loss on management IP of that router (same physical interface. Same subnet.)
(And i can confirm that there was no problem with 5.22. Shame on me, it was cracked, but it worked. Now i have legal version and it does not work. Lol)
I emulate intel e1000 on that VM.
I’ve exactly same problem…!!
We have a Supermicro board, with xeon processor
With RouterOs v6.12-x86 we have horrible packet loss…!!!
But with RouterOs v5.26, everything goes very well (no packet loss)
have somebody an update about this topic?
thank you…!!
Notice: For support from Mikrotik staff, write to support@mikrotik.com - Mikrotik does not generally offer support on the forum, this is a user forum
I disagree.
This forum is also to exchange experiences with other users Mikrotik.
In this case x86 users.
Of course, Mikrotik must post an update about this issue.
You didn;t get the point, if you want to make a problem/bug report then you have to mail the mikrotik team since this forum isn;t for reporting issues.
why not?
if you see all mikrotik forum you can check all users posts mikrotik issues,
and share information with other users, in order to try to find a solution .
Because it;s hard for devs to track every bug/problem through different users posts, it would be nice a bug tracking system..
Ok, if I put this issue in forum , maybe others users can report more info about this issue.
BTW, I will try next week same configuration with a CCR instead a x86 Supermicro based computer.
