x86 Web Proxy - Not Working?
I reloaded a fresh install of x86 ROS after my hard drive crashed recently and noticed that my web proxy appears not to be working. I’m able to format the drive, and as well, check the drive but do not notice any date flowing through the proxy while viewing from the Winbox Web Proxy Settings (Status) window. I have the correct NAT and Redirect TCP 80 to 8080 set, and it was working prior to reloading ROS 3.13. I also notice the same thing on my RB433AH using a SD card (which was working fine) till I loaded 3.13. Is this a bug? I believe I saw something referencing the same problem in a post elsewhere.
-tp
I am seing traffic on my test router, but no hits…
I will keep looking and advice…
As it turns out, I had selected the wrong bridge interface in the NAT section so this is “my bad”. :sunglasses: :sunglasses:
Both the x86 and RB433AH are working great as advertised.
-tp
