Please excuse my lack of knowledge when it comes to Router OS, I bought a 750 GL router on my friends recommendation to use it at my new house.
I use the 750 GL to route the incoming 100 mbit internet, then a TP Link 1043nd gigabit wifi router to share the internet with my wireless products. This router only acts as a switch as I don’t use it’s wan port, the incoming cable is plugged into LAN1
My xbox 360 is also connected via wifi, and although I can connect to xbox live, my NAT is not open, which would be necessary for the best online experience.
In order to have an open NAT I would have to forward the following ports:
- TCP 80
- UDP 88
- UDP 3074
- TCP 3074
- UDP 53
- TCP 53
The 750 GL came with Router OS 5.2 which has a graphical interface (webfix), but I couldn’t find the corresponding menu/tab.
Could someone please provide me with a step by step guide on how to forward these ports.
On another note, I was wondering if there is anything more I should do other than ticking enable by the UPnP settings in order to get UPnP correcty working.
Thank you very much for your help!!
