XEN and 3.19
I installed a fresh 3.19 on a dual xeon board with ide drive to try XEN, I created the ROS image, added the VM, but when I hit start, it goes “running” for about 15 seconds then to shutdown. I followed the wiki. No error messages anywhere.
This is just a test ros 3.19 I havent bought a license for it, does that matter?
connect to console of VM and see if there are any console messages
i installed 3.19 with xen and queues not work, the restart and shutdown not working … I can see “stopping services”
please fix this bugs…
tks
did you tried with multi-cpu=no?
yes mi system it’s a single cpu
you mean Queues inside your XEN, or in the host machine?
in host… xen its installed and this queues not working inmediatly
:s
tks 4 all
Please fix this bug, v3.22 with xen queues not work
simple queues do not work on xen host machine
as far as I remember, queue tree should work
