When trying to make a routeros image file with Xen i get the error ‘failed to copy files to image’. Does anyone have any idea on how to fix this or am i missing a step? I’m reading directly from the Wiki.
Yes, thank you very much for the report. We discovered that it is not possible
to create an image on 3.17, we will try to fix it. Currently you may try to
use 3.13 version for Xen, it should work there.
Regards,
Sergejs
I will be trying that ASAP. I will post my results shortly.
check your memory usage - reduce for memory for host, leave some 32 or more MB for hypervisor and then assign memory to VM, then everything should be fine
The situation is this; I have VMWare Server 2.0 installed for testing evironment. I this server I have installed a Level 0 version of ROS 3.20 using the ISO file.
The Mikrotik VM has 512 Mb of RAM and 1 GB HD.
I configure the Ethernet interface to get into the mikrotik. Then in /xen I created a ros.img with 64 mb. It is created correctly and I setup memomry to unlimited.
Then I create a VM with this ros.img 64 M of ram and console server port 64000, CPU 1 and weight 256. I press OK an then the same error appears. “Status: Failed to setup VM”
After our MUM visit, we have deployed a fresh CF with a L4 Licence on a PIV with 1Gb of RAM.
I have follow the Wiki instructions line per line and no results. The status bar of the xen window stiils saying “Failed to setup VM” after enable this from console.
Same thing here. Followed steps exactly from wiki.mikrotik.com and error “failed to setup vm”. I’m using ROS 3.25. I have plenty of memory and disk space. Every single step went fine except when trying to enable the VM.
Mikrotik, why is this happening? Are we the users to blame? Has this feature been tested? Can we get a descriptive reason as to why this might be happening?
