XPON sfp ONU module
LTE3415-SH+
Hisense
Using WOLCK OLT device from China
( OLT Mac subscriber list )
Tested some ROS versions.
( need bridge-protocol mode set to “none” to any device behind the ONU sfp holder , as otherwise i have problems with VLANS/loop )
works in v6.44.6
works in v6.45.9
works in v6.46.7
works in v6.49beta27
works in latest 7.1beta5
- After up or downgrade cold reboot is needed to register ONU to OLT or send manual “reset” command from OLT
- The Link will not come up by itself after a hot reboot
- after sending reset from OLT it might take some time for link to come up.
does not work in latest bugfix 6.47.9
does not work in latest 6.48.1
( OLT keeps saying “Unauth” )
