XR2 and WLM54AG on 532 , stable????
is XR2 and WLM54AG stable on RB532 ???
has anyone tested it
we want to use XR2 for distribution and WLM54AG for backhaul (on 5ghz)
thanks in advance
regards
MKSB
Hy, i currently have a XR2 for distribution and a SR2 for backhaul on a RB532A r5, and it’s rock-solid!
thanks,
any one else using this kind of scenario with stability let us know.
regards and thanks in advance
MKSB
What is the amps/volts on your power supply? POE or Direct?
Hy.
I’m using a direct connection with the board (power side).
I use an old 12V stabilized power supply from old radioHAM project. It’s a 15A power supply, but the RB doesn’t require all this power! :wink:
mipland,
want to know if this will remain stable on Rb133 ???
thanks in advance
