XR2 dissappeared
I had installed two XR2 cards on Mikrotik 433AH, upon switch off and on, i only see wlan2, wlan1 i do not see it anymore. Tried to reboot but i cannot see that internface.
Any help ? is the card damaged ? or something can be done ?
Put them in one at a time.
Do they show up then?
Check your power supply voltage.
its been running for about a month now, all fine. i am not at the site now, thought i could do some sort of scan for hardware or something, looks like i would need to go there !
as i do not see that even in system/resources only one card is seen.
thanks.
