Xr2 question
Hello, i have xr2 with a 532A, the issue is that i have 1w amplifier connected to the card, how should works better without the amplifier or with, i read in the amp spec the max input is 100w, and the card has 600mw, how do i reduce the card power, o do i have to remove the amp.
thanks
What country are you in?
dominican republic
im using 2W amp with a Zcom 100mW AP and it works great. Whenever I put 200mW or higher AP, the signal drops significantly. Nevertheless I would suggest you to use it with amplification. Amps create noise..
