XR3 3.65GHz 2 Mile PtP Antenna Suggestion
What do you find to work best for a 2 Mile PtP 3.65GHz stand alone antenna? Replaceing a current 5.8 link that is experiencing a lot of interference. Please advise.
I have a 5 mile link running these:
http://www.roc-noc.com/product.php?productid=148&cat=38&page=1
I am seeing -60db so you might need to turn down the power at 2 miles.
Tom
how much bandwith do u get with it?
20.5Mbps in both directions at the same time using tcp
i am using the full 20MHz channels
Tom
ive two olds 3.5 alvarion XL and I can use the build in 23dbi antenna, did u try it with in turbo mode ?
XR3 isn’t FCC certified to use the entire 3.65 band, only the lower 25MHz without contention protocols.
Turbo on 3.65GHz isn’t legal in the US where roc-noc is.
We are only allowed 25MHz of bandwidth here on the XR3. One reason I haven’t jumped on that boat yet…
OK. but just to know it how much bandwith can deliver. same internal test .etc
