XR9 Conversion Table - Here it is!
Here is the conversion chart for the XR9:
4 (2427) 907
5 (2432) 912
6 (2437) 917
7 (2442) 922
I have searched, and searched, and searched to finally find it in a forum post on UBNT.com.
Please archive this for others. It was a pita for me to find. Guess I should have not put the sticker in a box that is 300 feet in the air huh :wink:
I wish you would have just posted. I’ve got several of them right here in front of me. I also set them all with a scan list only showing those 4 channels, helps me remember which is what is who is why…
so guys what will happen if I choose 2412 for ex. will it work?? or if I have a superchannel license and choose 2500 Mhz that will go up ?
4 (2427) 907
5 (2432) 912
6 (2437) 917
7 (2442) 922
It will work and will broadcast in licensed channels. The card is suppose to have a filter to cut down on out of band noise that will cause significant signal drop above 928 or below 902.
0ldman
thanks for ur information, cause in 900 band is just 2 channel on 20 Mhz and they are near across, so Iwas wondering that .
