xr9 correct freq in router os
will the xr9 ever be viewed in router os correctly
I was planning on using one so I’m curious what is not working?
it’s working fine, but as the card has a built-in frequency converter, RouterOS sees it as 2.4GHz, while it actually works at 900MHz. Ask UBNT to provide you with a frequency conversion chart.
It’s to hard for them to provide!
I’ve requestet a chart for XR1, XR7 and XR9 with no luck!
Only found a chart for XR9 on a resellers site.
It’s really professional… :laughing:
They send a XR9 frequncy chart every time I buy a card from them? I consider them professional, however It would seem you could e-mail them and get the information.
Yes when i buy a card… i don’t want to buy something that i can’t use, if the area i used for GSM or other…
Yes emails and support tickets, and no luck! only on the XR9… where i got a no go from the people who handle the frequency’s in Denmark.
And i want to use XR7 or XR1 then, but no info from UBNT…
But why can’t they put does chart’s on the website???
It’s so little info they give!
I think the chart is in the pdf specs.
Only for the XR9!
For XR7 the only info is “RADIO OPERATING FREQUENCY 760-780MHz”.
According to ubnt, the conversion for the XR1 card is -2200MHz. So, for 2412MHz selected in the driver, would mean 212MHz.
Do you have anything to confirm this???
Here is the XR9 Freq Table
http://www.ubnt.com/company/newsletter/0105.html
I hope this help you…
Can you provide something on XR1 and XR7?
mostly XR1…
