Does Mikrotik ver 3.17 have the power offset auto adjust to max when the card is set to default power output? I have found a chart from 8/2007 ( http://www.ubnt.com/downloads/ubi_mtik_power.pdf ) that shows that mikrotik automatically adjusts for the sr9 card but not the xr9. What should I be using for output power on these to get the max output of the card?
Thank you,
Oz
