"Yes" autoresponse
Does anyone know a way to answer "y"automatically after running the command "system backup load name = bkp.backup;?
I’m creating a script that takes the backup file generated in the RB1, writes and performs locally the “system backup load …”.
Dear,
I runnin scheduling script and it worked normally without "interaction"of y.
The interaction occurs only when it is on the console.
