Ok, first of all, I’m new to this forum and MikroTik. I already have read a lot, but I must miss something very basic.
I received the (new) RB2011UiAS-2Hnd-IN as I’ve read it should be a fine router…
Basic: I can ping the unit
http://IP does not work
telnet IP does not work
First connected RB2011 to my general network, it should receive IP and with my desktop on wifi I should be able to find it and connect to it. I use only Mac’s, so the Win admin program I ran by Par. Express.
The software could not find the unit. Guessing it could had to do with router - wifi - emulation …
Took my laptop (also mac), direct connected to Router ETH1
Can ping, no https or telnet.
Unit gives standard IP 192.168.88.1
I can ping that.
If I enable DHCP server on my laptop, RB2011 receives IP fine. I can ping on that too.
I receive MAC properly in DHCP-server-log.
On the display it mentions ether1-gateway, link-ok- negotiation done
in terminal (OSX):
telnet 192.168.1.24
Trying 192.168.1.24…
in terminal (OSX):
telnet admin@192.168.1.24
admin@192.168.1.24: No address associated with nodename
Maybe this also helps, a traceroute does not seem to reach te unit at the end.
I did expect to run into some problems, running wifi - extenders - and hotspot functions, but not at this stage connecting to it. I tried the back to factory defaults by display.
any help is appreciated ![]()
