YouTube High ping problem
hello, well I’m from peru - chimbote and well, I’m driving Mikrotik and as I have a couple of problems since I have implemented.
well, I have a client and when it comes to youtube, this is the ping gets too high, as you can see in the image:
and no I can do, I have my clients for simple queue, nothing more, and then a friend told me I had to implement the queue tree but not how, if they can spend some code to improve it’d be something very grateful.
It should be noted that 200.48.225.130 is the IP telephone and the DNS is the IP 10.0.5.1 Mikrotik, The 10.0.5.51 is the IP of AP Senao EOC 2610. good thanks hope you can help me.
check their simple queue, they are probably maxing out the available bandwidth, which is causing the high ping times.
if so a properly setup queue tree will help, check the wiki, there should be plenty of examples there
