Layer7 protocol filters peek into passing packets. The problem with the method is that in modern times, almost all browsing is using SSL/TLS encryption, including youtube. As the contents of connection is encrypted, layer7-protocol can not easily see URL and hence the whole concept doesn’t work.
Monitor as in “see what are people watching” - absolutely not.
Monitor as in “see how much data is going to/from youtube” - also not really:
At the moment, there is no way to reliably detect all youtube traffic by content of packet. You can block youtube by blocking youtube IP addresses (and instead of IP you can use hostname which will be automatically resolved by DNS to all currently available IP addresses). that will block clients from accessing youtube user interface, therefore users will be unable to play any video.
However, if you want just monitoring, not blocking, you must monitor both user interface and video delivery. Unfortunately, for video delivery youtube use “*.googlevideo.com” (for example https://r5---sn-uxanug5-hxay.googlevideo.com) which can’t be added to address lists because wildcards cant be resolved to IP (infinite amount of combinations in wildcard). You would have to speficy each domain/ip address which youtube use and thats not really possible. You will either not pick up all addresses or you will pick more than just youtube. Therefore it is unreliable - any results will not correspond with reality and there is no way to say how big the error is. It can be few percents, it can be hundreds or thousands of percents
Fasttrack was disabled. By the way, i already resolved my issue. I used dynamic address list but i will test it if this is stable. Thanks for your reply assistance.
Do you realize that a multitude of other google services are provided from the same servers (google cache) like youtube, so although your address-lists refer only to the domain names used by youtube, limiting traffic for the ip numbers on these lists may also limit google earth & maps (and google search of course but it should not be a big deal)?
